Well it is time again to upgrade my computer, and of course I gotta stop by Tom’s to make sure my choices are solid.
So here is what I am looking at:
Intel Core i7-3930K 3.2GHz 6-Core Processor
Corsair H100 92.0 CFM Liquid CPU Cooler
ASRock X79 Extreme6/GB ATX LGA2011 Motherboard
Corsair Vengeance 16GB (4 x 4GB) DDR3-1600 Memory
Mushkin Chronos Deluxe 240GB 2.5" Solid State Disk
Western Digital Scorpio Black 250GB 2.5" 7200RPM Internal Hard Drive
EVGA GeForce GTX 680 4GB Video Card (2-Way SLI)
>>or<<
Asus GeForce GTX 690 4GB Video Card
Corsair 500R Black ATX Mid Tower Case
Corsair 850W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply
http://pcpartpicker.com/p/hlPy
Approximate Purchase Date: Before 10/01/12
Budget Range: $2000 - $3000 usd
System Usage Most Important: Gaming (EVE, Planetside 2, COD: MW3, etc…) and to a lesser extent photo processing/manipulation (Lightroom/Photoshop).
Are you buying a monitor: No
Parts to Upgrade: Building complete system except Win7pro(64bit), optical drives, mouse, and keyboard
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg
Overclocking: Maybe. If Tom’s has the specs, or someone knows good settings.
SLI or Crossfire: Maybe. GTX690 (future SLI) or GTX680 in SLI?
Your Monitor Resolution: Starting at 1920x1080. Plan monitor upgrade to 2560x1440. Suggestions?
Why Are You Upgrading:
I usually replace my gaming computer every 4-5 years. The last one was golden until recently (Asus Striker II Formula MOBO, Intel Core 2 Extreme QX9650, 2x Gigabyte GeForce 8800GTX SLI, Crucial Ballistix DDR2 800 PC2-6400 - 4 GB, 2x Western Digital Caviar WD7500AAKS RAID 0, Case: Silverstone Temjin TJ09B).
Additional Comments:
I’m looking for your opinions on making this build last me another 4-5 years. My lucky wife will be inheriting the old one.
The main reason is because the MOBO is starting to have problems starting up and increased crashing during games. The start-up problem may have something to do with USB because when it happens I just have to: Unplug the Keyboard/Mouse - Shut down - re-plug and it starts fine. Not OC’d anymore and not really worth diagnosing/upgrading IMHO.
Questions for the pro's:
1x GTX690 with SLI added later, or 2x GTX680 now.
Reuse one of my Western Digital Caviar WD7500AAKS instead of the Western Digital Scorpio Black 250GB 2.5" 7200RPM? Old vs. New.
Your monitor suggestions for future 2560x1440 resolution.
Thanks in advance for considering my build & commenting.
--Smirkingone
>>or<<
--Smirkingone
