Help a noob finish his first ever build
Last response: in Systems
Okay basically, Im very new to this and I've jumped in head first as they would say, I basically ask for your expertise to insure my build is correct.
The List so far:
CPU: i5-2500k
GPU: gigabyte 7870 oc 2gb
RAM: 2x Kingston hyperX 4GB 1600mhz
HDD: Samsung F3 1T 7200rpm
Mobo: Asrock z77 extreme4
Case: Cit vantage type-R gaming case
Now being the noob that I am could you make sure those are compatible, possibly what psu I will need because I don't have a clue and apart from a dick drive what other parts do I need. P.S If items can be improved for little or less please let me know. Thankyou
More about : noob finish build
Related ressources
The List so far:
CPU: i5-2500k
I would change the 2500k for a 3570k, get more RAM if you can afford it, and get a XFX 500w or 550w core edition (550w if you can but 500w or 450w would suffice)
AND IF YOU OVERCLOCK get the hyper evo 212+
I would go for the i5-3450 (i think thats the number) if you don't plan to OC, you don't need a K edition, it's probably around same price and a slight bit faster.
I couldn't find your case, so i'll recommend you try searching newegg for the 'most reviewed', the cases with 1000's of reviews are mostly pretty good ones.
I wouldn't go with an OCZ PSU (or rather, I wouldn't trust them without a good review from jonnyguru. Seasonic, Corsair, XFX, PC Power & Cooling are some of the standout brands. If you don't plan on adding a second GPU for Crossfire, you'll be fine with a good 500W PSU (don't trust anything with a regular retail price under 40$, generally speaking). Beware cheap/junk PSUs they can damage your components if you get unlucky.
I think you have a 2x4GB set of RAM, correct? If that's the case, ignore the more ram comments people have made. 8GB is plenty, I would assume those that recommended more RAM thought you had only 4GB (which is still ok, but generally 8GB is cheap enough that it's worth getting), it's written a little funny :) .
A few recommendations for PSUs for you:
^ This is a great PSU
^ This is still a good supply, but a little less power and a little lower tier design.
^ This guy should be good, and is modular, but maybe worth checking johhnyguru/hardware secrets for reviews. It's a good brand, just not sure where the model lands (I would expect it to be better than the Corsair CX500, but don't know). Also it's white, which is weird.
I agree with the rest of your post. But i would stick with the 3570k. It's his first build and im sure once it's together it's going to fuel his desire to do more and more and eventually hes going to say I want to try OC'ng lol. Don't limit yourself.
My opinion :)  and respecting DjScribbles if your 100% sure there's no chance you want to try oc'ng in the future OP then go with the 3450.
Ask the community
