I have a eMachines comp that I plan to switch to a bigger case so I can upgrade the psu and graphics card. Specs are listed below. Wanted advice on which graphics card would perform well with this particular motherboard. Also any advice on psu and case would be helpful. Budget is around $250-$300. Mainly planning on playing League of Legends and WoW, plus some older RTS games I cant seem to get away from :lol: Thank you for your responses. Cheers!
eMachines EL1852G-52w Pentium Dual-Core 3.2 GHz Small Form Factor PC
General Features:
Microsoft Windows 7 Home Premium 64-bit pre-installed w/CoA
Intel Pentium Dual-Core E5800 3.2 GHz processor
2 MB L2 cache, 800 MHz FSB, Intel Virtualization Technology (VT-x), Intel 64, Idle States, Enhanced Intel SpeedStep Technology, Thermal Monitoring Technologies, Execute Disable Bit
Intel G41 Express Chipset
3 GB DDR3 RAM (4 GB maximum)
1 Terabyte (1TB) GB SATA hard drive
DVD±RW DL SATA drive
Integrated Intel GMA X4500HD graphics
Integrated audio
Integrated 10/100/1000 Gigabit Ethernet LAN
Multi-in-One memory card reader
Power button
Supported Media:
Secure Digital (SD)
Memory Stick (MS)
Memory Stick PRO
xD-Picture
Motherboard Features:
One (1) PCI Express x16 slot
One (1) PCI Express x1 slot
Two (2) SATA ports (occupied)
Two (2) 240-pin DIMM sockets
220-watt power supply (100 - 240V, 50/60Hz)
Unit Dimensions:
10.4 x 3.9 x 14.6-inches (H x W x D, approximate)
General Features:
Integrated audio
Power button
Supported Media:
Secure Digital (SD)
Memory Stick (MS)
Memory Stick PRO
xD-Picture
Unit Dimensions:
