Hi all,
I've recently purchased a brand new computer with two 2xGeForce GTX 680 in SLI and ASUS VG278 3D-monitor connected using dual-link DVI cable bundled with the monitor. However Vision 3D only works until I enable SLI. After that I can physically see double-image on the screen, but 3D IR transmitter doesn't work (and so are glasses). It's 100% reproduceable and here is a way:
1. Install nVidia drivers using "CLEAN INSTALL".
2. Enable Vision 3D - all works just fine. It also works in games.
3. Enable SLI - all 3D-related things stop working - all that I see is double-image. And it stays that way even if I disable SLI afterwards - only clean install solved the problem.
I've tried 301.10 and 301.42 drivers - the effect is the same. But since it works at times I tend to think that this is a driver issue, not a hardware one.
Please let me know if anyone had this problem, and if there is a solution to that.
And another side question - I'm thinking about buying two more monitors for 3D Surround setup - but I'm not sure that current GPUs would be able to handle that. I'm playing modern games like BF3 and like moving all quality handles all the way to the right, so if anyone has any information about whould such a setup handle BF3 at Ultra settings and 5760x1080 resolution - I'd appreciate you sharing it with me.
Thanks in advance!
Thanks in advance!
