Looks as if my motherboard just went kaput so I am in need of a "newish" build. The problem is the timing of this situation is less than ideal. A totally new build sandwiched between my vacation getaway last month and my girlfriends birthday and Christmas lurking on the horizon means that I should show some restraint. How would you best suggest I go about recycling some of my old parts into a newish Frankensystem.
I don't really play games as heavily as I once did but would like to have a system that can play something like borderlands 2 well. Would also like to position myself to not have to upgrade for about 2 years. I've started doing a bit of photography so I will be using photoshop a bit but that shouldn't be a deciding factor.
What I currently have:
HAF 932
Core i7 Processor i7-920 2.66GHz 8 MB LGA1366
OCZ OCZ3P1600LV6GK DDR3 PC3-12800 1600MHz 6GB Platinum XTC
Western Digital Caviar Black 1 TB SATA III 7200 RPM 64 MB Cache (times two)
XIGMATEK Dark Knight CPU cooler
Corsair CMPSU-850TX 850-Watt TX Series 80 Plus Certified Power Supply
XFX Radeon 4890 (two of these)
Sony Blu-Ray player
I also have a monitor and all peripherals
So what I want to know is what parts are salvageable and what should be scrapped. I don't really have a budget but I would like to get things up and running for a minimal cost. Is it worth it to just get a new motherboard or would it be better to get new cpu/board/ram?
I am kind of out of the loop as far as the new technology goes but from what I have gathered in brief time I spent researching is the core i5 3570k may be the sweet spot for someone with my user profile.
HAF 932
Sony Blu-Ray player
