Hi All,
I'm looking to put together a decent computer that will play Starcraft II and Borderlands 2 smoothly but also perform well with Windows 7 (I have XP now), Photoshop, 3DS Max and even video editing.
My budget is roughly $1,000 total (but I'm flexible) and this is what I have put together on Newegg.
Also note that I already have a 1920x1200 monitor (the resolution I always use), keyboard, mouse, speakers and also a GeForce GTX 285 which I will keep for a few more months until I upgrade. When I do upgrade, I'll pick one of the top graphics cards from this list that's under $300 that's also a good value for the price. Right now it would be the GTX 480 or 670 as they seem cheap for their performance rating. I don't plan on doing SLI.
http://www.videocardbenchmark.net/high_end_gpus.html
Here are the parts I'm considering buying:
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
Model #:Three Hundred
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
ASRock Z75 Pro3 LGA 1155 Intel Z75 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Model #:Z75 Pro3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157304
SeaSonic M12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
Model #:M12II 620 Bronze
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
Intel Core i7-2600 Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 2000 ...
Model #:BX80623I72600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115071
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-16GBXL
Model #:F3-10666CL9D-16GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231486
Kingston HyperX 3K SH103S3/240G 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD) (Stand-Alone Drive)
Model #:SH103S3/240G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820239046
I chose these parts for their reasonably good speed, compatibility, decent prices and also for their high reviews.
My questions:
1. Are the parts all compatible?
2. Are there any replacement suggestions, especially considering my future graphics card update? These parts cost $794.94 total but I'm not opposed to spending over $1,000. I'm thinking mostly about the memory here. I'm not sure if paying $50 more will provide a significant improvement.
3. Is the power supply enough (or is it overkill) for a future GTX 670?
Any other thoughts or suggestions are appreciated. (I'm also not opposed to shopping elsewhere for savings but this was just the list I've been putting together for some time.)
Thanks much!
Model #:Z75 Pro3
My questions:
Thanks much!
