Gtx 560 max heat 90 in 99% load after 20 minutes
hadi suliman
79
guys
i did furmark test for 20 minutes and i got the following results
burn in test ,1920 x 1080 -37 fps
MSAA 0x
FPS min 16 max 40 avg 38
frames 45605 - time 20 minutes
temp 89c max 90c
vddc 1.012v fan speed 100%
gpu load 93% ,mem load 12%
is that good or bad ??
How many fans in your case? not including the ones attached to your graphics card or CPU.
Googled Cairo and its saying your daytime temps are around 37c not sure if you live near there but that could be the cause if your room temp is near that.
What are your temps while gaming?
hadi suliman
79
ok i played crysis 2 max settings and the temp reach 70 maximum ...i heard fur mark put a crazy load on the GPU and there is no such huge load in the real world and my ambient is hot the card in idle is 40 -42c
Manually set the fan speed to 80% with msi afterburner and check the temps every few min. The gpu core can run stable even at much hotter temps (got a 9800gt that is stable up to 112c) but the rest of the card won't last long at those temps. The mid range range cards are simply not built as well as the high end in that regard.
Not knowing which model that yours is I suggest that you keep it clean and if the case isn't great just take off the side panel for more air flow.
hadi suliman
79
but when i tried to play a game it doesn't reach this kind of heats .. maximum 75c!!
hadi suliman
79
it's too hot yes but i played crysis 2 max and the temp was 70 75c maximum
70c+ isn't uncommon for these cards when fully loaded but there is room for improvement by far. I am currently considering a project that I have been thinking about for a few days. Might mod a standard tower style cpu cooler so that it can be used on my 256bit gtx460. I hate the stock cooler but don't want to spend heaps on money on a new cooling system.
hadi suliman
79
you know for gaming using pc, this days is too expensive u need a lot of sittings and expect more but the results are not so good
maybe a console will do the job...and let the pc for your work i think !! damn
hadi suliman
79
yes i have the two ..hot country (egypt) and a bad air flow ..but about the fan what do u mean about fan configuration
i have two fans connected with gpu and in msi afterburner 50% as default in idle is there anything else ?? i dont know
paddys09
858
paddys09
858
Well if you have no fans in your case all that hot air is just building up, definitely get as many as you can fit in the case. Your gaming temps are fine, nothing to worry about, just lay off the benchmarking until you get the case fans sorted out.
hadi suliman
79
thank u ...you helped me a lot :bounce:
