Solved
Help with new build, no clue where to go.
Last response: in Systems
Approximate Purchase Date: The sooner the better!
Budget Range: $850 U.S.D. After Tax and also After Newegg price checking from Fry's.
System Usage from Most to Least Important: Gaming rig, CS6, Sony Vegas.
Are you buying a monitor: No
Parts to Upgrade: New build.
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg, Fry's.
Parts Preferences: I prefer AMD but realize that Intel is better at most tasks. So, whatever best fits my needs.
Overclocking: Yes
SLI or Crossfire: Maybe
Your Monitor Resolution: 1360x768
Additional Comments: I want this build to be able to support Mac OSX Mountain Lion, Lion, or Snow Leopard. I know that sounds like a bit to ask, but I've looked around and asked questions on other sites and they tell me just to go buy a Mac, however I really don't want a Mac, I just want to be able to run the OS. I've read that Gigabyte motherboards are good at it and that Intel CPU's are a must. Realistically speaking this OS is only going to take up about 150GB of space.
More about : build clue
Best solution
here you go
a bit over budget if you live near orange county you could do better
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($229.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler ($19.99 @ Newegg)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($142.86 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($41.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($89.99 @ Newegg)
Video Card: Sapphire Radeon HD 7850 2GB Video Card ($195.98 @ Newegg)
Case: Antec Three Hundred Two ATX Mid Tower Case ($77.98 @ Newegg)
Power Supply: Antec Neo Eco 520W 80 PLUS Certified ATX12V / EPS12V Power Supply ($56.98 @ Newegg)
Optical Drive: Samsung SH-222BB/BEBE DVD/CD Writer ($21.98 @ Newegg)
Total: $877.74
(Generated by PCPartPicker 2012-09-15 04:24 EDT-0400)
Related ressources
I would also suggest a build like the above, however you may want to consider a GTX 660 instead of the HD 7850 seeing that Sony Vegas takes advantage of CUDA cores. However this will cost you about $30 more and it does not worth it to go cheaper in other components (other than maybe the case, but make sure that is still a quality one like this:
See also here a bit different build at the same money. It actually trades an non-overclockable CPU for a better GPU, the $817 one :
http://forums.anandtech.com/showthread.php?p=33928643#p...
Ask the community
