Sign-in / Sign-up
Solved
Installation of cabinet fans in corsair 300r
  • New Build
  • Connection
  • Corsair
  • Systems
  • Product
Last response: in Systems
September 15, 2012 3:38:24 PM
hello everybody...................... this is my first gaming build system..... so at present m stuck on a particular issue regarding the connection of cabinet fans.... i owned a corsair 300r cabinet recently and i m confused regarding the installation of the fans..... m using asus- m5a88m motherboard but it only comes with one chasis fan connector...... rather my 300r got two fans installed in it...... one at front and the other at the back.......... so m using only the rear fan cause i donno how and where to connect other fans installed on my 300r :cry:  :cry:  ????................. any suggestions or advise will be a great help for me................. hoping to get reply soon.................. with regards........... (aki james.)............... :)
More about : installation cabinet fans corsair 300r
Best solution
September 15, 2012 3:48:52 PM
If the front fan has a three pin power connector, then you need an adapter to allow it to run off of a molex connector from your power supply.
APEVIA Model CVT43 Power 4 PIN Adapter TO 3 PIN Fan Adapter
This should work for you (assuming the front fan power connector has three pins).
-Wolf sends
September 15, 2012 3:55:53 PM
thnk you so much ................ guys................... :)
m
l
September 22, 2012 3:51:45 AM
Best answer selected by akijames1234.
m
l
