Will all these computer parts work together? Plz respond ASAP.
6 answers Last reply
More about will computer parts work together respond asap
  1. If you are getting 8GB of RAM you'll need windows 7 64 bit not 32 bit (32 bit only supports ~4GB). RAM is also cheap. I'd pick up a dual channel RAM with 1600 cas9. In fact they are basically the same price CORSAIR Vengeance 8GB. I wouldn't trust the power supply that comes with a computer case. They are generally terrible. Other than that, it looks fine.
    I have looked for a power supply and found this,
    http://www.newegg.com/Product/Prod [...] 6817152036
    will this work with the parts I want?
    And i will pick the corsair vengeance.
  3. Yes, that psu is more than enough for your system.
  4. That link doesn't work. How do you know it is good crewton?
  5. I've used newegg enough to know :P it's n82e1 and then the product number. The link at least had the product number.
  6. Alright. Thanks Crewton for helping. Now to buy all the products and start gaming.
Build Gaming Computer Systems Product
