Hello everyone!
I have opened this thread with the intent to seek advice on the system I have built for myself. I intended to build a very good gaming system with the intention of later adding an SLI, a system that would allow me to run any game on highest settings at a 1900x1200 resolution with 60+ fps. During the building of this pc I my intentions were on getting some of the best parts whilst preserving a decent performance/price ratio, with a tendency to go for pricier only to make sure the quality of the product is superior. The things that I am interested in are:
1. Is this system compatible and would it all fit together nicely?
2. Any recommendations for replacing a part, whilst preserving a decent performance/price ratio.
Motherboard: ASUS P8Z77-V PRO LGA 1155
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131819
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Graphics: EVGA 02G-P4-2678-KR GeForce GTX 670 FTW 2GB 256-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130787
HDD: Seagate Barracuda ST2000DM001 2TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148834
SSD: Corsair Performance Pro Series CSSD-P256GBP-BK 2.5" 256GB SATA III
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233227&Tpk=corsair%20256%20gb%20ssd
Source: COOLER MASTER GX Series RS750-ACAAD3-US 750W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171053
Case: Cooler Master CM690 II Advanced Edition USB 3.0 ATX Case - Black/White
http://www.amazon.co.uk/Coolermaster-Advanced-Black-White-Edition/dp/B006NZKPK6
Edit: forgot the RAM
RAM: CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233302
