Greetings.
I need some help. What I'm trying to do is to build an ITX rig, the problem is that I wanna build in a case that isn't very tall. I've been used to playing alot of Xbox, and it sort of sits on the table in my living room nicely, not taking up alot of space. I also like having a case i can just store next to the tv or put in the tv shelf. That's mainly why I would love to have a low case, I'm thinking sort of the shape like an Xbox 360. This brings out some problems I'm hoping to solve.
First comes the GPU problem. When mounted to a motherboard, high end GPU's stand upright, thus only fitting in cases that are tall. Now, an Xbox would never have space for a GPU standing upright, however laying down the GPU would fit, but then the motherboard would have to be upright, so that wouldn't work. What I'm wondering here is, would there be a possibility to have an external PCI Express cable going out of the PCI Express slot and then maybe mounting it on side and make GPU lay halfway over the motherboard? I haven't been able to find much info regarding this.
Next is the Powersupply. They are quite large and squared. What if this could be made rectangle and the height could somehow be put into it beeing longer instead. Could this be done and is there any PCU's like this? I know I might need to do something custom here, the question then is, would it be possible to take apart a normal PCU and making it slimer and longer? Perhaps a professional company could do this?
This might sound like a little to high efford build, I'm also doing watercooling on the CPU and GPU to save some space. I'm gonna post some drawings of the case and what my idea will be to give you guys a better look on what I'm thinking. Meanwhile thanks for any answers and ideas guys, mostly appreciated!
