Closed Solved
Power Supply for this Graphics Card
This graphics card http://www.newegg.com/Product/Product.aspx?Item=N82E16814161405 has and AMD HD 7850 inside. The power supply however, OCZ700MXSP does not show up on the recommended page (http://support.amd.com/us/certified/power-supplies/Pages/listing.aspx ) for the HD 7850 though. Is this ok still?
4 answers Last reply Best Answer
More about power supply graphics card
  1. Best answer
    Ignore those certified lists. 700w is more than enough, but that particular model has a bit of an iffy reputation. Do you already have it, don't worry, it is so over power that it will be no problem, but if you haven't bought it, look at the recommended psus in the FAQ.
  2. If you only plan on putting one card in your system, get this psu...
    PC Power and Cooling Silencer MK III 600W Modular 80PLUS Bronze Power Supply
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817703036&Tpk=pc%20power%20and%20cooling%20600w
    If you plan on doing Crossfire or SLI in the future, get this...
    CORSAIR Enthusiast Series TX750M
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139030&Tpk=corsair%20tx750m
    If you don't care about the semi-modular capability, get this...
    PC Power and Cooling Silencer Mk II 750W High Performance 80PLUS Silver
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817703027&Tpk=pc%20power%20and%20cooling%20750w
  3. Best answer selected by mikey21211.
  4. This topic has been closed by Mousemonkey
Radeon Power Supplies Graphics Cards HD Graphics Product
