My friend wants to build a computer because he bought a prebuilt one a while ago and it was way overpriced. So he thought he should build one. Thing is, he is in a wheelchair and has very limited use of his arms and no use of his legs. Since i had build one before, he asked me to help. So i need a ~$3000 build that would suite him perfectly.
Approximate Purchase Date: e.g.: Late September, early October
Budget Range: ~$3000
System Usage from Most to Least Important: Gaming, video editing, school work
Are you buying a monitor: Yes, needs a 1080P monitor UNDER 24", anything larger makes it very had for him to see the whole screen
Parts to Upgrade: All
Do you need to buy OS: Yes, windows 7 ultimate
Preferred Website(s) for Parts: Newegg
Parts Preferences: i7 3770k
Overclocking: Yes
SLI or Crossfire: If needed
Your Monitor Resolution: 1080p
Additional Comments: PC needs to be low maintenance, so nothing like a custom water loop, he needs a blu ray drive and a CD burner, also would like USB 3 and a 2 TB HDD, needs a wireless adapter, preferably one that goes into the PCe slot, and it would be best if it was somewhat future proof
thanks!
Overclocking: Yes
thanks!
