I just finish my first build! Yay!!
Ok, my CPU comes with a integrated graphic card. [i5 3570k]. In order to install a new graphic card, do I need to first disable to integrated graphic card first and then install or can I just install the graphic card onto my mobo and it'll automactically switch over to the installed graphic card? Btw I'm using the gtx 550 ti.
Thanks
For helping!
Thanks
For helping!
