Solved
Will these 2 parts work.
430w Psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023
with
7770
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102993
Yeah I know cutting it close but will this work, Not asking what would be better because I would love a 1200w psu but I don't have the money for a new psu and thats the one I got.
Using a 4650 right and I can't tell what the power consumption is its different for each site.
more info
I got 1 fan, asus 79 evo, 4gb ram, 3core phenom 3.3ghz.
I noticed people in comments using 450 gtx with it.. pretty sure those are more power hungry then the 7770, Though I am not tech pro.
Also did this little power consumption calculator was around 299w
6 answers Last reply Best Answer
More about will parts work
  1. I'd get a CX 500 v2. That PSU looks dead dodgy.
  2. " Not asking what would be better because I would love a 1200w psu"
    Guess that was not specific enough to say this is not a compromise, this is will it work not what is better.
  3. Pick up an antec VP cheaper, and ca power the 12v rail more than the thermaltake unit can.
  4. Best answer
    If the PSU actually outputs the amps it claims, you should be able to run it.
    Calculating the power output on the 12v rails (good PSU's only have one), you should get a max of 348W (The supply has no business being called 430W).
    Assuming worst case scenario.
    AMD CPU: 125W
    Mobo: ~30W (much likely less)
    HD7770: tough to find out, but 100W at absolute most (likely much less).
    Total Draw on the 12v rail: ~255W
    You should be fine, though that supply is fairly low quality. I would advise replacing it as soon as you can to a proper unit.
  5. Best answer selected by killzon32.
    AMD CPU: 125W
    U sir are a smart cookie :P Thanks for actually explaining to me the reasons instead of the "Derp 800w"
New Build Power Consumption Systems Product
