Modular female issue please! help
  • Power Supplies
  • Cable
  • Components
Last response: in Components
January 30, 2013 6:49:02 AM
im building a budget computer have everything here was installing stuff no issue but the case I got comes with 3 fans pre built in to the front side and back all the fans take a 4 pin I guess modular power connection well they are all female and my psu a 700 watt coolmax came with plenty of cables but not one male modular cable it does have 3 female available but not a single male one so im left with every fan not being able to function and cant find what I need I figure maybe I can get a male to male cable but everything ive found is for male to female nothing that will do the reverse of what I want ... please any suggestions or help is appreciated
More about : modular female issue
a b ) Power supply
January 30, 2013 6:52:35 AM
Fan usually connect to small fan headers on the motherboard. Maybe the fans have an adapter on.
m
l
January 30, 2013 7:10:05 AM
wow the only help I need is a slap in the face ... they can connect either male or female 4 pin just need to look at the back side of the cable the front is female back is male thanks for the quick reply ... im gonna sulk for a bit lol
m
l
a b ) Power supply
January 30, 2013 7:23:10 AM
haha no problem. Happens to all of us at least once. I generally forget to plug in the CPU power at some point.
m
l
January 30, 2013 7:30:57 AM
lol yeah its been awhile for me putting together a new system but your reply did help I went to check if there was an adapter and found that the plugs were double sided :)
m
l
