Power supply questions
hentaiboi_
111
hi guys... i have 2 questions... first is just found this on the web... is this a credible guide when getting a good power supply?
http://www.eggxpert.com/forums/thread/323050.aspx
second question... same wattage different brand... which one is worth buying?
Corsair HX 1050
http://www.corsair.com/en/power-supply-units/hx-series-power-supply-units/hx-series-hx1050-power-supply-1050-watt-80-plus-gold-certified-modular-psu.html
or
Cougar GX 1050
http://www.cougar-world.com/products/power_supplies/cougar_gx_v2.html
here in the philippines the price difference of cougar from corsair is around $60... thanks guys...
Hi - 750-850w covers CF/SLI, water cooling, OC & all the components.
A 550w unit will comfortably run a system with a 7970 or 680
& anything below them. You would only need more than 850
if you were to CF/SLI 7990/690, and those are $1000 cards each.
Hi - Cougar has some iffy units, but their GX series seems good. I'd say
the cheaper one is ok to go with. Check the warranties tho.
Corsair HX series is one of their professional series of PSU's and should be of a quality build because of that.
I'm not too familiar with Cougar, a couple of their GX series got good reviews.
Why 1050w? are you running 3 graphics cards? If not,
you have serious overkill, which does no real harm except
for the high cost.
Tom
hentaiboi_
111
ok here is the build... currently upgrading right now
core i-5 3570K
MSI GD55 z77
32GB DDR3 1600Mhz ripjaw
* palit GTX 560Ti 2GB
coolermaster hyper evo 212
*150GB raptor
1TB WD caviar black
*DVD drive adding another one
*antec 900
Sound Blaster Recon3D Fatal1ty Professional
* recycled parts from my Q6600 system
PSU i'm using right now is acbel 625W... i don't have an idea what is the recommended wattage for my system...
and the problem is just in case i want to upgrade my video card, i'm having trouble getting the mid to high tier cards due to low wattage...
following this guide right now... in getting a new PSU...
Hi - the eggxpert list is ok to use, keeping in mind it can't cover all the
good and bad psu's out there. So, if you find a model you are interested in,
not listed, check for reviews from jonnyguru, hardware secrets, Hardocp, or
post here in the forum.
Also, in looking at your sys specs even considering you are upgrading, you
just don't need anywhere near a khw psu unless you are going to CF
two 7990's (then 1khw is not enough) or SLI two gtx 690's.
There is no harm in the hx1050 other than an unnecessarily high upfront cost.
I'd recommend a quality 750 or 850w unit in case you wanted to
CF/SLI anything below the 2 gpu's I listed above and still have headroom.
Tom
hentaiboi_
111
ok so 750-850 watts is the recommended for my system... how about when i decide to buy an corsair liquid cooler, OC my 3570K and buying a video card that is factory OC'd in the future i might consider SLI/Crossfire... do i need more than 850? how about future proofing?
