Need Help?
  • Power Supplies
  • ATX
  • Compatibility
  • Components
Last response: in Components
January 30, 2013 2:07:47 PM
Need to know what kind of power supply would be compatible with Cooler Master -CAC-T05-UW?
Features:
ATX Mid Tower
ATX, Micro ATX compatible form factor
2 External 5.25” drive bays
2 External 3.5” drive bay
2 Internal 5.25” drive bays
7 expansion slots
USB, Firewire, Audio ports
More about : question
a b ) Power supply
January 30, 2013 2:13:51 PM
Hmm, do you know the model name of the computer case? I'm assuming it will fit with any ATX power supply which is really common. Let me know your budget as well and if your in the US or Canada or elsewhere.
m
l
a c 1218 ) Power supply
January 30, 2013 4:28:14 PM
The Cooler Master Centurion 5 CAC-T05-UW accepts Standard ATX PS2 power supplies.
Standard ATX PS2 PSU Dimensions: 150mm W x 86mm H x 140mm D ( 5.9" W x 3.4" H x 5.5" D )
The depth is the only spec that is allowed to vary (i.e. high wattage PSUs will usually be deeper than 5.5". E.g. Corsair 1200W is 200mm / 7.87" in Depth).
m
l
