Hi forum! New user here..
tl;dr: No video signal. Things to try? And what is the minimum functionality I need for getting a signal?
I'm supposedly upgrading dad's pc (a project which has evolved into replacing it in parts), and I just can't pin down the reason why I'm not getting a signal to the monitor.
current specs:
board: msi k9a2 platinum
cpu: amd phenom x4
psu: 700W
ram: DDR2 pc2-8500
hdd: 2 ide drives
gpu: Asus GT520
other:
some sata dvd drive
usb bracket
old, PCI wifi modem
hp w2808h 1920x1200 monitor
things I've tried
switching motherboards (which are compatible with the cpu)
switching cpu's (which are compatible with the motherboard)
switching psu's (700w and 400w)
switching gpu's (xfx HD 5850 and Asus GT520)
switching monitors (tried with an old CRT and an old, flat lcd)
moving the gpu between PCI-e ports
switching output for video (gpu has HDMI, DVI and SVGA, tried them all)
staring desperately into the box
grinding teeth
At this point I'm wondering if I'm hooking up something wrong. The board is getting main power, and I've connected the external cpu power. The card requires no external power. When I hit the power button I get lights, fans and I hear the hdd's spin up. Only the monitor says no signal.
Thanks for any help, guys.
current specs:
cpu: amd phenom x4
psu: 700W
ram: DDR2 pc2-8500
hdd: 2 ide drives
gpu: Asus GT520
other:
some sata dvd drive
usb bracket
old, PCI wifi modem
things I've tried
grinding teeth
