Can my system run Amd radeon hd 7770 phenom ii x4 specs included
  • Power Supplies
  • Computers
  • AMD
  • Radeon
  • Components
Last response: in Components
January 30, 2013 10:00:35 PM
I have a computer with windows xp, ati radeon graphics, and amd Athlon 64 processor also a gig of ram and 160 om the hard drive and I was wondering if I were to put those into my computer would it work?
More about : system run amd radeon 7770 phenom specs included
a b ) Power supply
a b À AMD
January 30, 2013 10:20:49 PM
Look on the motherboard manufacturers website to see if you motherboard can support the CPU and if it has a PCIE x 16 slot then you can use the graphics card as long as your power supply has enough watts. If your CPU is a single core then most likely the answer is no and if its yes you need more RAM as well.
m
l
