Hi, I've recently moved from home back to university and my computer is running a lot slow than it normally does, it's only a few months old, if i try to play something like Arma2 or Skyrim the games are now lagging quite noticeably where as they use to run smoothly, along with things like right click responses taking longer and such.
I'm not to sure what the problem is it's all setup the same but also it says (using Coretemp) that all cores of my cpu are running at 0-10 degrees C, where as it use to run at 50-60C though im not sure how true that is.
