Hi,
Here's my outline. I've chosen most parts and wanted some critique
What is your budget?
$800
What is your resolution?
1920x1080
What are you using it for?
Mostly gaming.
What is your upgrade cycle?
1-2years
When do you plan on building it?
next 2 or 3 weeks
Do you plan on overclocking?
No
Do you need an Operating System?
No
Do you plan to add a second GPU for SLI or Crossfire?
No
Where are you buying your parts from?
Australia, http://www.pccasegear.com
ASRock H77-PRO4-MVP Motherboard
Intel Core i5 3470
Sapphire Radeon HD7870 2GB GHZ
G.Skill Ripjaws F3-12800CL9D-4GBRL (2x2G) DDR3
Antec VP550P 550W Power Supply
TP-Link TL-WN751ND Wireless PCI Adapter
Western Digital WD Blue 500GB WD5000AAKX
BitFenix Merc Alpha Mid Tower Case
I have monitor/keyboard/mouse/optical drive
Thanks in advance for any advice
$800
1920x1080
Mostly gaming.
1-2years
next 2 or 3 weeks
No
No
No
Intel Core i5 3470
