I want to know that if a monitor can use the graphics card if it is connected to the motherboard instead of the graphics card outputs, will this work and if it does will it reduce performance? Thanks.
its the 7970 and I'm getting a monitor with hdmi input next week so it'll be okay then but the current monitor only has d-sub. I guess i'll just wait, do you know if there would be any problem with having a dual monitor setup with one input from graphics and the other from onboard graphics (no gaming/eyefinity just a side monitor). Thanks for replying.
