Sign-in / Sign-up
New build help
  • Homebuilt
  • New Build
  • Processors
  • Graphics
  • Systems
Last response: in Systems
September 18, 2012 1:48:12 AM
so i have my new build all set up and i run my games but it seems like the resolutions are not as sharp as i would like them to be so i was wondering if i could get some advice on this. Thank You My build is as follows:
Nvidia geforce 660ti
600WPSU
16GB Ram
segate 1.5 tb 7200 rpm
amd fx 6100 six core processor 3.30 ghz
Windows Ratings
Processor AMD FX(tm)-6100 Six-Core Processor 7.3
Memory (RAM) 16.0 GB 7.8
Graphics NVIDIA GeForce GTX 660 Ti 7.9
Gaming graphics 4095 MB Total available graphics memory 7.9
Primary hard disk 1259GB Free (1397GB Total) 5.9
More about : build
September 18, 2012 8:48:38 PM
If you have an older lower resolution monitor, then thats definitely the problem. Otherwise that build seems to be capable of handling games at a pretty good quality. Maybe if you could tell us what game you're trying to run @ what settings? Oh and your monitors resolution as well.
m
l
September 25, 2012 2:00:20 AM
I'm using a 40" TV and i'm trying to run Guild Wars 2 and a few of my steam games. I try and go for high settings since i figure it should be able to handle. my current res is 1080i 1768x992
m
l
