Solved
PC powers on but power button light stays blank, help!
My computer powers on, but singal to monitor, no beeps, or lights. The CPU fan keeps running at high speed, and it's very noisy. CPU is generating no heat. I have tried unpluging everything to the machine and holding down the power button for 30 seconds. Checked the ram and removed one of the sticks, took out the battery and then back in again, and I checked for dust but everything seems very clean. Still nothing.
Emachines EL 1200-06w
Processor : AMD Athlon 64 2650e / 1.6 GHz .
Memory : 1.0 GB / 4.0 GB (max) .
Hard Drive : 80 GB - 7200.0 rpm .
Operating System: Microsoft 7 Ultimate
Optical Drive : DVD±RW (±R DL) / DVD-RAM .
Graphics Processor : NVIDIA GeForce 6150 SE Shared video memory.
Graphics Controller : Integrated .
Monitor: eMachines E19T6W (Works on other computers)
Power Supply: New Liteon PE 5221 08
Motherboard: Acer DA061L Boxer AM2 61
2 answers Last reply Best Answer
More about powers power button light stays blank help
  1. Hi
    have you located cmos reset jumper (if you removed battery you may need to wait a long time to discharge capacitor)
    have you checked voltages 5V & 12V on a spare molex connector black = 0 = ground, yellow = 12V red = 5V
    On Intel CPU ATX 12 V to motherboard is critical to start up
    Have you checked capacitors near to CPU (part of regulator circuit) for bulges or leaking ?
    (bad capacitors needs expert to replace or new motherboard)
    regards
    Mike Barnes
  2. Best answer
    same probem here ,, have you got any solution till now ?
Power Supplies Components
