Help choosing videocard
  • Graphics Cards
  • Asus
  • Graphics
  • Product
July 30, 2012 7:26:12 PM
Hi,Good day everyone could you help me to choose a videocard im just a beginner on assembling my own gaming pc.
My choices are:
Zotac 550ti AMP edition 1gb
EVGA 550ti FPB edition 1gb
Gainward 550ti (Golden Sample)
Palit GTX550ti
Asus GTX 550ti dc top slighlty higher than the rest.
MSI R6770 1gb or asus 6770
ASUS 5770 (Used,my friend is selling it 50% price)
Well,all of these cards are on almost same prices im having a hardtime choosing a brand. actually a videocard,my videocard gts250 just gave up on me recently because of power malfunction.
My pc specs is :
CPU:AMD phenom II x6 955 BE
Mboard:760gm-p23(fx)
ddr 3 8gb ram
psu:FSB Supersonic 550watts
casing:Vs-3 advance
monitor:Hpx2301
Thnx im hoping to buy it tomorow or 2 days from now thnx :)
More about : choosing videocard
July 30, 2012 7:51:36 PM
I assume your limit it somewhere around 150-200.00, i would recommend the http://www.newegg.com/Product/Product.aspx?Item=N82E168... as its on sale 50 off and comes in under 200 while still being quite a powerhouse card. It has a recommendation of 500 watt or larger with 2 6 pin pci express connectors so if you have those or adapters that would probably be the best bang for your money.
m
l
July 30, 2012 8:04:40 PM
all the card i have mentioned is 140-150$ which in my currency is 6k php, the card you recommended me is about 8k :(  and hard to find here in the philippines :(
m
l
September 1, 2012 3:45:49 PM
go for gainward GS, if your not in a very tight budget then you should go for Gainward 550ti OC, or SC
m
l
