So I'm trying to come up with a good gaming PC that will last for the next few years.
A couple of questions that I have are, will the parts listed down below work together?
How long should this PC last before needing a upgrade?
I do a lot of gaming and rendering, would it be good at both?
If I do go ahead and get this, would there be extra cables, wires ect. that I would need to buy. If so what?
Is 750 watt good enough for 2 GTX 660 Ti's in SLI?
Should I get a water cooler instead?
As for the parts.
Cooler Master HAF 922 http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
ASUS P8Z77-V PRO LGA 1155 Intel Z77 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131819
2x GTX 660 Ti in SLI http://www.newegg.com/Product/Product.aspx?Item=N82E16814127696
CORSAIR HX Series HX750 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Intel Core i7 3770k http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
G.SKILL Ripjaws X Series 8GB (2 x 4GB) http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
120 gb SSD http://www.newegg.com/Product/Product.aspx?Item=N82E16820233191
2x 1Tb HDD http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Asus DVD burner http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Windows 7 Home Premium 64 bit http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
COOLER MASTER Hyper 212 http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Please tell me what you think, and please answer the questions I have.
As for the parts.
