Hi Brett. Thanks for taking a moment on this.
I have found that sometimes a USB port manager will downgrade the connection, despite the external device being capable of higher performance. So a 2 device will sometimes run as a 1 on a 2 port. More often than not these days, that would be triggered on an internal USB port connecting with an external USB hub which has one or more devices connected. It seems that an occasional misfire with device communication will evidence it too, though that is appearing less often than it had earlier.
And I've had cheap USB 3 cables prove themselves incapable of actually running USB at 3.
So the answer may be more complicated than your reply might be construed to indicate.
Therefore I was looking for a Windows utility to perform the check. If you do not know of such a utility, don't concern yourself further about it.
Regards.
Ye Old IT Greybeard
