Yes No
Ads
Tom's Hardware > Forum > Windows 7 > General Discussion > BSOD every 30 minutes HELP
Forum Windows 7 : General Discussion BSOD every 30 minutes HELP
I have no idea how to read this. What could be the problem? and how do I fix it?
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: ntoskrnl.exe
PFN_LIST_CORRUPT
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x0000004e (0x0000000000000099, 0x0000000000100faf, 0x0000000000000000,
0x000000000010102f)
*** ntoskrnl.exe - Address 0xfffff80002c94c40 base at 0xfffff80002c18000 DateStamp
0x4e02aaa3
Reply to mlozevsk
Firstly....Update all drivers from the Microsoft Update site....
This is something you missed here and posted without searching the forum...
Bugchecks Explained: PFN_LIST_CORRUPT
OSR Staff | Published: 24-Aug-04| Modified: 24-Aug-04
What Happened?
Windows tracks physical pages of memory using a table called the Page Frame Database. This database (which actually is just a big one-dimensional array) is indexed by physical page number. As a result, the page frame database is typically referred to as the Page Frame Number list or PFN.
Every page of physical memory has an associated PFN entry. Each PFN entry contains information about the state of its corresponding physical page in the system. This state includes information about whether the corresponding physical page is in use, how it’s being used, a count of active users of the page, and a count of pending I/O operations on the page.
Depending on the pages state, a PFN entry may be on one of several lists that the Memory Manager maintains. The listheads for these lists are simple global variables that are used for quick access to PFN entries of certain types. For example, one such list would be the list that contains all the modified pages that need to be written to disk.
Because all the PFN lists and entries are present in the high half of kernel virtual address space, they are subject to corruption through stray pointer accesses (such as by errant drivers or other similar kernel-mode modules). Also, the count in the PFN that tracks the number of I/O related accesses to a given physical page can be corrupted by improper MDL handling.
Whenever Windows detects that any of the PFN lists or any of the PFN entries themselves have become invalid, the system halts with a PFN_LIST_CORRUPT bugcheck.
Who Did It?
This bugcheck usually occurs for one of two reasons, the first reason being memory corruption. If there is a buggy driver in the system that is writing on memory that it does not own, it could easily corrupt one of the PFN lists or entries. In order to rule this out, you should run Driver Verifier with Special Pool enabled for suspect drivers in the system. This will hopefully allow you to catch the misbehaving driver in the act of scribbling memory, instead of receiving a crash sometime later when the O/S discovers the damage.
The second cause for this bugcheck is incorrect MDL handling. For example, one use of MDLs is to allow you to "lock" the physical memory that backs a virtual address range so that the memory stays resident while your driver is accessing it. This is achieved by using the MmProbeAndLockPages DDI. One of the things that this DDI does is take out a reference on the PFN entries of the underlying physical pages, ensuring that the Memory Manager does not page them out. The corresponding DDI to undo this operation, MmUnlockPages, is responsible for decrementing the reference counts taken out in the previous call. If a driver happens to call MmUnlockPages too many times on an MDL, the reference count on the underlying PFN entries could drop to below zero (to 0xFFFFFFFF). The system considers this to be a critical error, as one or more of the PFN entries is obviously invalid. Therefore, this bugcheck will occur.
If your driver or a driver in your stack is being blamed for a PFN_LIST_CORRUPT bugcheck, go over your code and make sure that you are properly handling your MDLs . Remember that even if you do not create or destroy any MDLs directly, you play a part in the creation and destruction of them if you handle IRPs whose buffers are described with DIRECT_IO. Driver Verifier and the checked build of Windows can help pinpoint IRP and MDL handling errors.
How Should I Fix It?
How this is fixed varies depending on the reason of the bugcheck. Using Driver Verifier and the checked build of the O/S should allow you to pinpoint the driver that is either corrupting memory or mishandling MDLs. If the offending driver is not a driver that you have any control over, the only available option is disabling the driver until a fixed version is available.
Related WinDBG Commands
· !memusage
· !pfn
Related O/S Structures
· nt!_MMPFN
· nt!_MMPFNENTRY
· nt!_MMPFNLIST
Related O/S Variables
· nt!MmBadPageListHead
· nt!MmStandbyPageListHead
· nt!MmModifiedNoWritePageListHead
· nt!MmModifiedPageListHead
· nt!MmFreePageListHead
· nt!MmZeroedPageListHead
· nt!MmRomPageListHead
Courtesy
http://www.osronline.com/article.cfm?article=334
------------------------------ Passiveness causes others to pass us by
http://valid.canardpc.com/cache/banner/2026250.png
Reply to alyoshka
So as the article says...
"How this is fixed varies depending on the reason of the bugcheck. Using Driver Verifier and the checked build of the O/S should allow you to pinpoint the driver that is either corrupting memory or mishandling MDLs. If the offending driver is not a driver that you have any control over, the only available option is disabling the driver until a fixed version is available."
It's most probably a corrupt driver....
Reply to alyoshka
And make sure the Pagefile is not on the SSD too.
Reply to alyoshka
So, I've seen that code be a couple of things. It can be a faulty keyboard (usually if its a PS/2 keyboard) or a corrupt system file.
If its not the keyboard try repairing windows
http://www.sevenforums.com/tutoria [...] stall.html
Reply to arges86
As this BSOD is typically caused by either a bad HDD or RAM, I'd start testing those two, ASAP.
First, test each stick of RAM with memtest86, one at a time. If no errors, test the HDD via chkdsk. Might also want to do a SFC /scannow, just in case theres a driver problem.
Reply to gamerk316
There are 1949 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Moving an operating system
By Pinhedd, 9 hours ago:
You will not be able to drag and drop the files because that will not copy the parts of...
Best offers
Top experts
