Solved
Case fans randomly throttle
Last response: in Components
jnkweaver said:
MSI Afterburner has a fan control profile why don't you try that. It could be an intermittent sensor saying it is overheating.
I got my fan controller working, it is actually my CPU heatsink that is making all the noise. It never did this until i switched cases, no hardware was changed during the swap. Would i have to replace the motherboard or the heatsink in order to avoid this problem? No program i know has a cpu fan controller, not even my bios allows me to change it. The one you speak of in afterburner is for the GPU
Ok but to be fair in the beginning you were talking about case fans. I thought MSI could control anything on the motherboard my mistake.
You need to monitor the temps of the cpu when the fans ramp up to see if you are having temperature swings.
Speedfan can control CPU fansbut you have to set it up properly. Make sure you configure your PWM modes to software controlled.
Related ressources
Highest temp on my CPU has been 37°C, It shows no exact point where it starts up, sometimes at 36°, maybe at 37° but mostly random. The CPU usage may have something to do with it, sometimes it spikes from 5% to about 30% which I find odd as it is an I5-2320 and I don't recall seeing such spikes when just on the internet. If it may help, i have none of my case fans plugged into my motherboard and when I start up it gives me a case fan failure warning because they are plugged into the controller on my case. I have thought about plugging my CPU fan into a 3pin case fan header but I know that wouldn't end well
You should be able to turn off the warning by telling it not to monitor that portion (I have my side case open warning turned off).
As far as the cpu fan if the temp is not going up with the fan than it is probably a bad pwm signal from the motherboard. I think speedfan may be able to control the fans but if the motherboard is sending spurious signals I don't know.
I also wonder about the powersupply. Many weird hardware electrical issues is a bad power supply. What is the make and model and wattage of your powersupply?
My powersupply Is a Rosewill Xtreme 750w. I think most likely there is something wrong with a fan controller either in my odd bios which i cant find any updates for or my motherboard in general
jnkweaver said:
You could be right. What is your motherboard?
Standard one that comes with a Dell inpiron 620. I bought it because my parents didn't trust me to build my ow at the time but I have gained much more knowledge since then and now The cpu, hard drive, and motherboard are all that remain the same
Weird when I look for the Bios it is A04 but when I go through the OS then it is A08. Do you have A08 installed?
jnkweaver said:
Looks like it has been out for about a week.
64 bit
http://www.dell.com/support/drivers/us/en/19/DriverDeta...
32bit
Not sure if there is really a difference but they do have it separated.
Hey, thanks for hunting down the drivers. I'll install them and see if it makes any difference. If not, ill sell some *** I don't use and replace my mobo with an MSI one thats on sale and get a corsair H100 to finish off my computer
