Hey guys, I'm new here. I'm planning on building my own system in a couple months, taking as much advantage as possible of the Black November sale that Newegg puts on. This is my FIRST system, but I'll have a good friend who's done it before to help me through it (plus the internet seems to have several guides available).
$1,500 is the rough cap (I can go a liiiiiitle over it, but not much). This will be my working AND gaming computer, but since my work is just typing, the gaming is my primary concern. I want as much Gaming capability and longevity as possible: I want something that will remain capable and competitive for more than a year or two.
I'm using this website as a rough start: http://www.gamingpcbuilds.com/best-gaming-pc-build-under-1500/
I'm going with the Intel PC build, as opposed to AMD. NOTE: Editing as a result of feedback. Keep it coming!
CPU: Intel Core i5-3550 Ivy Bridge 3.3GHz (3.7GHz Turbo) LGA 1155 77W Quad-Core
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116505
GPU: Either an EVGA 670 or an MSI 670, both 2gig
Link: http://www.newegg.com/Product/Prod [...] 6814130787
vs.
http://www.newegg.com/Product/Prod [...] 6814127685
RAM: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Motherboard: GIGABYTE GA-Z77X-D3H LGA 1155 Intel Z77
Link: http://www.newegg.com/Product/Product.aspx?Item=13-128-546
Hard Drive: Western Digital Caviar Black 1 TB SATA III 7200 RPM 64 MB Cache
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Blu-ray/CD/DVD: Asus Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-Ray Drive
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135247
Case: Cooler Master Storm Enforcer USB 3.0 Mid Tower ATX Case:
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119240
PSU: OCZ ModXStream Pro 700W Modular High Performance Power Supply
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018
SSD: Crucial 128 GB m4 2.5-Inch Solid State Drive SATA 6Gb/s
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442
CPU Cooler: Cooler Master Hyper 212 Plus
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
EDIT: Big Question: If I upgrade my GPU to something like a 670, will there be a bottleneck somewhere else? I don't want to get a nice GPU and not be able to use it because I cheaped out somewhere else...
As I said before, this is my first computer I will be building. I have a few questions that I would love some help with:
1. Will an i7 be noticeably better for gaming than a cheaper i5?
2. Are any of these choices so mindbogglingly stupid that you want to hit me in the face? Which ones?
3. Are any of these choices notably OVER-powered or UNDER-powered for my needs?
4. Will this build actually work? Are there any alternatives to certain parts that jump out at you as you read this?
vs.
