NEED HELP!!
Is this stuff good or no im trying to build a ultimate gaming pc under 1200$
So heres my list so far and it comes 714$ and i still need a couple more thing can you help me or correct me
Intel Core i5 3570K
Sbertooth z77 lga 1155 Motherboard
Ripjaws 8gb ram
Gigabyte radeon hd 7850 2gb
And I know I need more. So what else do I need ? that would be good ? and under 1200$
20 answers Last reply
More about need help
  1. It's OK. For RAMs, I would choose from
    http://www.gskill.com/configurator2.php?pid=2&model=1549
    2x4GB kit, 1866MHz, 1.5V or 1.35V.
    Make sure that they would fit under the CPU heatsink
    So, what else? a CPU heatsink, SSD, HDD, DVD drive, monitor, Windows 7 or Windows 8 64-bit. And a case and power supply, of course.
  2. Just putting it out there...
    You can buy "kits" which include the motherboard, CPU and RAM. I have found this is usually a good option to go for as it guarantees that all these hardware parts are going to work very nicely with each other. It also cuts out a lot of research before hand, as you probably know, all CPUs do not work with all motherboards, and that counts for the RAM as well. This is of course sometimes a very exciting thing to do - matching up and CPU with a motherboard and then finding that it works a treat. But I find it very useful to buy these kits as it saves time and you know it's going to run smoothly.
    I would also recommend a 5.1 sound card. As you are building the "Ultimate Gaming PC", sound plays a vital part in the immersion of a game. However some motherboards these days do already come with integrated 5.1 sound chips so have a look at that first.
    One more thing to look out for is 64bit capability of your hardware. This shouldn't really prove an issue, but when I upgraded my system to 64bit my machine would just hang for no apparent reason. No error message or anything just freeze up completely to the point of me having to force it off with the power button. After extensive testing and troubleshooting, it turned out to be my internal WiFi card was not 64bit compatible and was causing the issue.
    Good luck building the rig, and have fun ;)
  3. PCPartPicker part list: http://pcpartpicker.com/p/BdOW
    Price breakdown by merchant: http://pcpartpicker.com/p/BdOW/by_merchant/
    Benchmarks: http://pcpartpicker.com/p/BdOW/benchmarks/
    CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
    CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($33.24 @ Amazon)
    Motherboard: Gigabyte GA-Z77X-UD5H ATX LGA1155 Motherboard ($180.98 @ SuperBiiz)
    Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($49.98 @ Outlet PC)
    Storage: Crucial M4 128GB 2.5" Solid State Disk ($107.95 @ Mac Connection)
    Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($73.49 @ Outlet PC)
    Video Card: Asus GeForce GTX 660 Ti 2GB Video Card ($273.98 @ SuperBiiz)
    Case: Fractal Design Define R4 w/Window (Titanium Grey) ATX Mid Tower Case ($99.99 @ Microcenter)
    Power Supply: Corsair Enthusiast 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($115.98 @ Newegg)
    Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($16.98 @ Outlet PC)
    Total: $1142.56
    (Generated by PCPartPicker 2013-02-03 08:50 EST-0500)
  4. Hi :)
    For the ULTIMATE GAMING PC you NEED the Ultimate gaming graphics card...
    This is mine >>>> http://www.powercolor.com/us/products_features.asp?id=423
    Thats $1000 ...lol
    So without it , you will have an AVERAGE gaming pc...
    All the best Brett :)
  5. ^ Dude be reasonable... his budget for the system is $1200 not only for the graphics card...
  6. Brett928S2 said:
    Hi :)
    Thats $1000 ...lol
    Show off! :na:
    But that is one sexy looking GPU though
    Hi :)
    He SAID he wants to build the ULTIMATE GAMING PC.... I am showing him he NEEDS to UP his budget....
    Or hes going to have an average gaming Pc...
  8. patrickthepink said:
    Show off! :na:
    Hi :)
    GREAT graphics as well lol :)
  9. Thnx Guys for the info HELPED ALOT
  10. Which build are you buying?
  11. Still thinking I liked this one.CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
  12. Would I be able to run like dayz, bf3 and stuff at high settings with no lag at a stable 30 fps or should I switch some things
  13. I have a GTX 660 Ti with an Intel 3770. I get 48fps on Crysis 2 (all settings on ULTRA and Depth or field pack and Tessellation Pack) Basically the highest settings on that game and i get 48fps!
  14. should I get the amd fx 8350 or i5 3570k
  15. for gaming the i5 3570K
  16. The 8350 is only better for Video editing...
  17. Get the i5 3570k it out performs my FX8120.
  18. Thnx Guys :)
  19. Brett928S2 said:
    Hi :)
    Ultimate?
    Within a budget, theres also an ultimate, so when someone comes along and does quad and squishes your rig, dont be surprised.
    Lets try to keep posts within the OPs requests
  20. JAYDEEJOHN said:
    Ultimate?
    Thank you lol!!!! :sarcastic:
CPUs
