Does capping fps to 60 in games reduce gpu power cons and heat?
- a new game i want is "capped" AT 60 FPS ...does that mean if i..... - Forum
- Does HDD reduce FPS in games? - Forum
- Bare minimum GPU and CPU to play high-end games at a low graphics settings at 60+FPS? - Forum
- Best CPU & GPU TO RUN GAMES AT 60FPS 1440P - Forum
- Does the refresh rate of a monitor cap the "FPS-age" of my games? - Forum
- SolvedDoes this build can play any Games on ultra settings without lag ? ( 60 FPS + ) Forum
- SolvedShould i turn on Vertical refresh on 60Hz monitor when GPU is making 120fps in games? Forum
- SolvedDoes a 144hz Display makes sense for 60fps gaming? Forum
- is there a way to cap every game to 60fps Forum
- SolvedMy gaming PC can run bf4 on ultra at 60 fps, but with minecraft shaders mod only 30-40 fps at most. Does anyone know why? Forum
- SolvedCheapest possible gpu for 1080p 60fps gaming? Forum
- Solvedwill a MSI GeForce GTX 760 Gaming Edition gpu. will i get around 60fps on bf3. at 1080p Forum
- SolvedHow much does setting power option to High Performance boost fps in gaming Forum
- What GPU will be best suited to max games at 1600x900 with 60+- FPS Forum
- [Build Help] Can a i5-3750k + 7970 gpu run most games over 60fps? Forum
- How much does setting power option to High Performance boost fps in gaming Forum
- More resources
