so my components to my system is as follows
mobo: ECS A780LM-M2 AM3 AMD 760G Micro ATX AMD
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135315
cmu: AMD Athlon II X3 450 Rana 3.2GHz Socket AM3 95W Triple-Core Desktop Processor ADX450WFGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103886
ram: Crucial 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model BLT2KIT4G3D1337DT1TX0
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148485
graphics card: ZOTAC ZT-50604-10L GeForce GT 520 (Fermi) 1GB 64-bit DDR3 PCI Express 2.0 x16 HDCP Ready
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500239
psu: Diablotek PHD Series PHD350 350W ATX12V V2.2 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822005
hdd: seagate 500gb 7200rpm sata
misc: Liteon DVD drive, Encore wireless adapter.
OS: Windows 7 Pro x64
PROBLEMS:
So whenever I try to use the IE some background processes crashes... (cant remember on the top of my head)
when i use chrome, i keep getting the "oh snap" error message,
when system is idle i get random crashes of background processes and/or memory reference error.
certain windows update keeps failing to install, namely "framework 4 related updates",
windows update freezes/hangs
furmark benchmark causes nvidia drivers to fail
sometimes BSOD after mentioned problems
Attempts to fix:
several fresh installs of windows
I thought it was a memory problem so I played around with BIOS RAM clock settings AND REPLACED the sticks (newegg sent me new ones)
ran memtest86+ over night and didnt detect any problems.
Now i'm starting to think its the video card thats the problem...
any help would be appreciated.
PROBLEMS:
Attempts to fix:
