Hi all, im building a new pc after using my current one for 4 1/2 years and was wondering if you can shed some light on the parts i picked out. i already have a case that i got for free so i wont be needing one of those. i have a budget of 700$ so if you can help find better parts that my current build, would be much appreciated. thanks in advance
cpu: AMD FX-8120 Zambezi 3.1GHz
motherboard: ASRock 970 EXTREME3 AM3+ AMD 970
gpu: MSI R7850 PE 2GD5/OC Radeon HD 7850 2GB 256-bit GDDR5 OR a EVGA GeForce GTX 560 Ti (Fermi) 2GB 256-bit GDDR5. i cant decide on which one to get. some people say they perform on almost the same and some say the 560 is better than the 7850 and vice versa.
ram: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
psu: Thermaltake TR2 RX 750W Bronze
hdd: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM
those are the parts i picked out, with a little help from my cousin. thanks again
