Thank you both very much for spending your time to help me out. I kinda upped my budget to 1600 and have created the following. but not sure if the parts i chose are as reliable as they seem.
Tower- COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Steel ATX Full Tower Computer Case with USB 3.0, Black Interior and Four Fans-1x 230mm front RED LED, 1x 140mm rear, 1x 230mm top, and 1x 230mm side
*link*-
$159.99
GPU- EVGA 02G-P4-2670-KR GeForce GTX 670 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Item #: N82E16814130782
Return Policy: VGA Standard Return Policy
*link*-
$379.99
Memory- G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C10D-16GAB
Item #: N82E16820231560
Return Policy: Memory Standard Return Policy
*link*-
$94.99
MB- ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813131821
Return Policy: Standard Return Policy
*link*-
$239.99
CPU-
Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770K
*link*-
$329.99
External HD- Seagate Expansion 1TB Black Portable Hard Drive STBX1000100
Item #: N82E16822178114
*link*-
$89.99
Heat sync- COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel ...
Item #: N82E16835103099
*link*-
$34.99
SSD- Kingston SSDNow V+200 KR-S3020-3H 2.5" 120GB SATA III Internal 7mm Solid State Drive (SSD) (Stand-alone Drive)
*link*-
$84.99
Cable OKGEAR 10" SATA 6 Gbps Cable, Straight to Straight W/ Metal Latch, UV Blue, Backward Compatible 3 Gbps and 1.5 Gbps
Item #: N82E16812123107
Return Policy: Computer Cables and Accessories Extended Return Policy
$4.00
OS-decided to pick up a new os- Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Item #: N82E16832116986
Return Policy: Software Standard Return Policy
$99.99
These parts should be compatible right? And for about 200 more i think are worth it. I'd appreciate some more feedback. But if no one replies I'll take into consideration the previous builds posted. i guess i shouldn't have put emphasis on a budget, rather building a very sick gaming rig, that i don't want to upgrade for years. I haven't messed with ATI since the 9800pro so how do their cards compare to the EVGA's that are so hard to beat in terms of reliability....at least in my experience?
