My AMD 6770 runs at 80C at 100% fan speed while gaming. Idle temp is around 47C. It's free of dust so that's not the problem. It's OEM and in a pretty cramped case. If I buy a new card with a good cooler on it (Twin Frozr III) will it still run hot because of my case or will the temps be better? I read that heat pipe cooling is the best but only if you have good airflow. Is there any card I can get that will run at a better temp? I think 80C is too high.
And spare the lectures on prebuilts, please. I'm aware of all the details. I traded a laptop for this machine and I think I got a pretty good deal for an i7, AMD 6770, and 8Gb RAM.
Also, I use MSI Afterburner to monitor the temps and have a custom fan profile set up. With out running the custom fan, my card gets 105C+ during BF3. Needless to say, I ALWAYS run MSI Afterburner.
Thanks in advance.
Edit: I should also mention that if I buy a new card I will also buy a new PSU which may or may not decrease temps as well. And I would probably shoot for the 7850 which I think is plenty for one 1920x1080 monitor. Oh, and I wasn't intending to be hateful with the comment about being lectured. It's just that I know how these threads usually tend to go. "OMGz build a real PC!" But seriously, this is what I have to work with right now and I see no need to build an entirely new system and scrap this one unless I can't do anything about these temps.
One last thing (I know I'm long winded ), my i7 hits around 60C on all cores while gaming with the stock cooler. That seems okay to me, so maybe the card is a dud? I suspect it's just bad airflow though. But I'll shut up and see what you all have to say.
Thanks in advance.
