I would like to ask the hobbyist and pro's their opinion on my current wish list build because i'm building for the first time and would most likely build what others recommend..so far my parts are
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard: ASUS P8Z77 WS LGA 1155 Intel Z77 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131822
Memory: CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) CML16GX3M4A1600C9B
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233198
Storage: OCZ Vertex 4 VTX4-25SAT3-256G 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227792
Case: COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
Power Supply : CORSAIR Professional Series Gold AX850 (CMPSU-850AX) 850W ATX12V v2.31 / EPS12V v2.92 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139015
I'm leaving the cooling and graphics cards to your recommendations..If possible i would like to stay up to the current parts available but without having to buy like rampage extreme or some other extreme version of a part.
My budget is within $1600-$2000..but cheaper is good
I would also like to know if the parts i picked were compatible with each other and if certain parts were overkill when paired with the other parts..any advice would be very much apprecaited..thank you
