Pc can't power on anymore?
i was playing bf3 online since 2 weeks and all runs fine ,when suddenly one day,was playin bf3 online , pc suddenly shut down and cant even switch on anymore?? :( :( :(
i recently built my pc since 2 weeks , here are the specs:
cpu intel core i5 3570
psu- Aerocool E80-700 watt
motherboard - msi h77ma g43
ram- kingston 4b ddr3 @1600
gpu- Asus GTX 560 DirectCU II
1 samsumg hdd 7200rpm
1 ssd 128gb ADATA
what is the cause ?? any solution??
thanx 4 helping
17 answers Last reply
More about power anymore
  1. have you checked that the AC cable is attached well to the psu?
    and you can open the case and look inside and see if you find any burnt components ( like caps example )
    and is your cpu 3570k or 3570?
    YES
  3. Would think psu died. Google paper clip test.
  4. Aerocool is not a top quality brand, particularly for stressful situations.
    I might suspect the psu.
    Can you test with a known good psu?
    You should only need about 550w.
  5. psu blow??
  6. cooler master is good?
  7. Nope. Xfx, corsair, seasonic. Google johnnyguru for reviews.
  8. any recommended model PSU for gaming ..not so expensive?
  9. have you checked that your psu isnt working?
    It depends on the model.
    Here is a handy list of PSU's organized by quality tiers.
    If you can, find a tier 1 or 2 unit.
    Your problem may not be the psu. See if you can verify that is the problem before buying.
    For a budget psu, Corsair CX series is OK.
    But you can't go wrong with Seasonic.
  11. Stupid can't edit message, here is the link :
    http://www.eggxpert.com/forums/thread/323050.aspx
  12. J_E_D_70 said:
    Nope. Xfx, PC power & cooling, seasonic. Google johnnyguru for reviews.
    Fixed.
    Corsair PSU quality varies widely from unit to unit, even in the same model line (for example, the CX430 is a great unit (built by superflower), but the CX500 is mediocre at best.
    Seasonic is really the only manufacturer there. XFX and PC P&C units are both made by Seasonic.
  13. i will go for seasonic 620W S12II ( A/80+ ) ??
  14. Like Geofelt said, your problem may not be the PSU.
    Borrow a PSU to test in your system. If it powers up, then go ahead and get a new PSU. If not, then you have a problem with one or more other components.
    If you PSU actually failed, instead of just the internal fuse melting, then the PSU may have taken other components out with it.
    If there's no PSU you can borrow, then I'd reccommend buying a corsair CX430 to test out with ($25 after mail in rebate). It's handy to have a backup PSU anyway, as I'm sure you can relate.
    good luck!
  15. ok..thank, there is no bad burn smell in psu
  16. yes its the PSU...i have one raptor r500 500watt psu, can i used it for my actaul spec?
  17. To put it bluntly, raptor bad. I wouldn't use that to power my toothbrush.
CPUs Battlefield
