Nvidia GPU thermal paste problem
August 1, 2012 2:50:55 AM
I bought a new budget pc used wth a Nvidia GeForce 9800 GT and it idles at 65 degrees C and at full load it goes to 95C.
Normal games it is 75-80C. So while browsing the forums I noticed that these temps where too hot and a soulotion was to re-appy the thermal paste.So i did this and now it idles at 62C and i'm worried because the other video cards idle at 40-50C and i recall something about the paste curing so i don't want to play games yet. what did i do wrong and why is it still so hot while idling?
a c 235 U Graphics card
a b Î Nvidia
August 1, 2012 3:07:20 AM
that card always ran warm, your temps look fine
m
l
August 1, 2012 3:11:28 AM
Thanks for such a fast response, but i have 2 more questions,1. do i still have to wait 25 hours of idle to go full load, and 2. is 100C unusual for this card?
m
l
a c 611 U Graphics card
a c 404 Î Nvidia
August 1, 2012 3:18:27 AM
You need to check your thermal paste label to see if it has a curing time. Many do not require curing, others do.
Hopefully, you used a very, very thin layer of paste and firmly secured the heatsink back on without any air bubbles. It's also hot, at least where I am this time of year, so high GPU temps are natural.
m
l
August 1, 2012 3:21:08 AM
najirion said:
hmmm.. that card is known to be reeeeeeeeeally hot. Applying thermal paste is really tricky (based on experience). Too much then its not that effective. It should only look like this:
http://benchmarkreviews.com/index.php?option=com_conten...
Hmm, the part that i put it on was square/rectangle so i'm thinking the previous owner upgraded the cooler.Also, i think i may have put a little too much. is it worth it to re-re-apply, or are these temps just as good?
m
l
a b Î Nvidia
August 1, 2012 3:22:06 AM
you should be able to go full load from the start. while the temps should drop a little from initially applying paste, it is not a drastic drop. a GPU can handle 100c but you need to look into a cooling solution if you are continuously reaching that mark.
m
l
August 1, 2012 3:31:41 AM
it does get that high while playing some games like farcry 2 and crysis 1 on full settings. What do you suggest as a cooling souloution. I have 1x 120mm in the rear blowing outward , 1x 120mm in the fron blowing into the case and then the generic PSU,CPU and GPU fans,the case is the Tsunami Dream. There is also a smaller fan that goes on the clear siding towards my monitor but i took the whole side off fo better air flow.
m
l
a b U Graphics card
August 1, 2012 3:32:28 AM
I had an 8800GT single slot solution, awesome card. The fan didn't kick up to 100% until it hit 100degrees, the card is/was 4 years old, and still going strong, so no, don't worry dude!!!!
m
l
a b Î Nvidia
August 1, 2012 3:35:42 AM
try MSI afterburner to increase fan speed
m
l
August 1, 2012 3:40:49 AM
I'm using EVGA precision, unless MSI afterburner increases all fan speeds?But, MSI is a company and EVGA is a company so i think they are the same thing
m
l
August 1, 2012 3:41:46 AM
Whoa, that really lifted my hopes up, thanks dude!
m
l
