Overheating problem?
Last response: in CPUs
So, back in the beginning of november i bought a new build, and ive noticed my cpu is constantly overheating, i read up on it and its something called "cpu throttling" or something like that. here are my specs
Motherboard: ASUS M5A99FX PRO R2.0
GPU: NVIDIA GeForce GT 640
Processor: AMD FX-4100
I also have 4 case fans with good airflow. when idle it is at 60C and when playing games it goes up to 85C and will crash often. any help?
Here is a picture of my HWmonitor when idle: http://imgur.com/NjIJIgT
More about : overheating problem
Yeah those temperatures are definitely a bit high. Ideally you want 30-35 on idle and 60-65 on full load... or better :)
I would remove the heatsink and give it a good clean then re-apply some quality thermal paste such as Arctic Cooling MX-4.
Unless this over-clocked? In which case you may need to look at reducing voltages, clockspeed or getting better cooling.
Have a quick read of this to make sure you have the case fans set up correctly too - http://www.tomshardware.com/reviews/cooling-air-pressur...
