Archived from groups: microsoft.public.windowsxp.customize,microsoft.public.windowsxp.help_and_support (More info?)
The error message you receive and what you're doing might help. Also check
Event Viewer for errors.
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
"Alex Coleman" wrote:
| Some of my applications are complaining that they can't find certain
| things to do with COM.
| Unfortunately, I have no idea what COM is and I am not much wiser
| after using Google although I think it may be linked to ActiveX.
| If I have disabled ActiveX in IE (I am told it is a security risk)
| then would that affect stand-alone applications which have nothing to
| do with IE?
| Can I re-install COM?
