Rightmark cpu clock problem
hi i used progrm RMClock.exe (rmclock_235) RightMark CPU Clock Utility (RMClock) 2.35
i have cpu "core 2 duo t8100" with 2100 Mhz clock
i noticed that when i exit the program the cpu clock goes to 800 Mhz
and when i start RMClock.exe it goes again to 2100 MHz
i wanted do have 2100 mh without using RMClock.exe as it is normal
and i used RMClock_WipeOut.reg but unfortunately
after this the cpu is always on 800 MHz
no mater what p-state i set in the management page
please help me to restore ability of my cpu to work on 2100Mhz without RMClock.exe
thanks
please help
best regards
1 answer Last reply
More about rightmark clock problem
  1. hi
    i am not allowed to edit or delete so i write again with corrections
    i used progrm RMClock.exe (rmclock_235) RightMark CPU Clock Utility (RMClock) 2.35 as described in this thread:http://www.tomshardware.co.uk/forum/264222-10-intel-t8300-underclock-result-problem#t1958738
    i noticed that when i exit the program RMClock.exe - the cpu clock goes to 800 Mhz
    and i usedresetting of settings of the program but unfortunately
    no mater what p-state i set in the management page.
    seems the program is not perfect so
    thanks
    please help
    best regards
CPUs Core Management
