Turbo boost or overclock = less heat
I was wondering if any one has done any testing on using turbo over blk for higher or lower temp results.
Im wondering if using 190blk 20x at 3800 no turbo
180blk 21x at 3800 with turbo
Both same Vcore.
Witch do you think will give lower temps?
Iv been using non turbo for a while now, and im at around 55-67C max at 190x20=3800.
No c state.
No spread spec.
No Turbo.
Ht On.
1 answer Last reply
More about turbo boost overclock heat
  1. FYI its i7-920 DO
CPUs Overclocking Heat Turbo Boost
