Power supply compatible with cooler master cac-t05uw
Last response: in Components
February 4, 2013 12:29:53 AM
I Need a power supply that is compatible with Cooler Master CAC-T05-UW
a c 1168 ) Power supply
February 4, 2013 12:37:56 AM
The Cooler Master Centurion 5 CAC-T05-UW accepts any Standard ATX PS2 power supply unit.
Standard ATX PS2 Physical Dimensions: 150mm W x 86mm H x 140mm D ( 5.9"W x 3.4"H x 5.5"D )
The Depth dimension is the only physical attribute allowed vary depending on the power supply's capacity.
m
l
