Volume Control
Archived from groups: microsoft.public.windowsxp.customize (More info?)
I have two volume controls: the first is SoundMax 4.0 that comes with the
motherboard's on-board sound, the second id WXP's sound control.
How do most use these controls? Set SoundMax to default and use WXP when
recording from Line In, or set WXP to default and use Soundmax?
Can you turn one sound control "off"?
TIA
2 answers Last reply
More about volume control
  1. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    > TIA
    To turn off, or at least remove from systray, the WinXP sound control
    right click its icon -> Adjust Audio Properties -> Volume tab
    and then uncheck the "Place volume icon in the taskbar" option.
    I don't know SoundMax but if it has all the necessary features it
    should be able to handle the various playback/record settings
    so you shouldn't need WXP's utility.
    In my case I had Nvidia's soundmixer loaded but it doesn't want
    to keep the settings I make in it so I wound up going back to
    Windows' volume control.
    >>ANIME SENSHI<<
    Marc D. Williams
    marcdw@charter.net
    http://tvdog.shacknet.nu/ -- DOS Internet & Tandy 1000
    http://www.geocities.com/wilmarcdw/ -- Win3.x Makeover
  2. Archived from groups: microsoft.public.windowsxp.customize (More info?)
    "Marc D. Williams" <marcdw@charter.net> wrote in message
    news:MyzOe.9723$1g2.8566@fe05.lga...
    >> TIA
    I removed windows volume control from the taskbar a long time ago, but it
    does not remove the control from the OS, or should it. I open it from the
    start button. But to record LPs through the line-in jack I have to adjust
    both volume controls which is a minor PIA. I'm curious as to what others do.
Configuration Default Customization Windows XP
