Best cpu cooler for Overclocking
I currently have a hyper evo 212+ I want to go to 5ghz And i need A better cooling solution Im currently thinking of the
http://www.amazon.com/Thermaltake-Frio-Universal-Cooler-CLP0575/dp/B004PIRAXI/ref=sr_1_1?ie=UTF8&qid=1359979370&sr=8-1&keywords=frio+ock
or the noctua
http://www.amazon.com/Noctua-Heatpipe-Bearing-Cooler-NH-D14/dp/B002VKVZ1A/ref=sr_1_1?s=electronics&ie=UTF8&qid=1359979404&sr=1-1&keywords=noctua
Now i like the look of the frio 100x more But which is better? Also which coolers would be better than the ones i mentioned
26 answers Last reply
More about best cooler overclocking
  1. I was under the impression that the noctua was the best air cooler, i could be wrong however.
    And i'm pretty sure the h100i from corsair is even better than that, however that is a clc.
    I don't think you would successfully get to 5GHz though.
  2. Ive manged To get 5.1ghz on 1.45v. I can get 5ghz on around 1.43v. The problem is my temps sky rocket with this hyper evo> haha. I think I got lucky in the silcon draw this time. The noctua is just so ugly. However if it gives the perfomance ill get it.
  3. I can't find it now, but LinusTechTips on youtube did a review between the h100i, the noctua nh-d14 and one more cooler, using all the same noctua fans (can't remember which ones though.
    I'm pretty sure the h100i won using a push pull with 4 120mm or 140mm fans
  4. been loads of people having problems with the h100i
    from the leds playing up to noises from the pump etc
  5. Is there a cooler as good as the noctua that does not look like ass? Haha
  6. problem is all those top end air coolers are huge lumps
    theres also the Phanteks PH-TC14PE
    at least you can get it in different colours to match your setup
  7. I might get that one. I see there's a white version and my case is white. Ill see some reviews cheers for that
  8. no problem
    it gets great reviews
    though like all the big air coolers you need to be carefull if you have high profile ram
    theres also the corsair h80
    got my 2600k at 5ghz with one in push/pull
  9. Actually, just go and grab yourself the H80i or wait for the H90 which is supposed to be much better at cooling. I have H80i and it is good. There's no pump noise apart from start up which you get from all water cooling kits. Keeps my CPU at 44-47 under 100% load and never breach that. So if you don't like the D14 which is the best air cooler that trades blows with the top closed loop water coolers then just grab the H80i/ Zalman LQ320/ NZXT Cracken 60/ H100i/ or just wait for the H90/H100.
    And don't worry about losing your top 240mm fan. You still have rear exhaust fan if you choose to go with H100i and all the 240mm coolers. Or just leave it there and get the 120mm coolers i.e., H80i etc.
  10. depends if you are in a hurry
    have been looking at the new swiftech watercooler
    it can be used like a h100i etc as a closed loop cooler
    but has the capability of being upgraded like a custom loop
    much better pump than corsair etc
    out near the end of this month
    http://www.overclock.net/t/1345816/various-swiftech-h220-240mm-aio-water-cooler-expandable
  11. Yea my back 120m should be fine. Also i dont know if my case is the best for that? I mean my case is a full tower however i dont know if its desinged for water cooling. I think i get the rs 360 for around $160.
    If i got the h80i would i be able to keep my top 240m?
    That kit looks nice. I want to see more reviews especially from Toms and then I might have to sell my H80i and that has to have 5 degrees improvement or nothing.
  13. i have the storm trooper
    which is your case just in black
    yes the h80 fits on the rear without affecting the top fan
    and yes that swiftech unit fits in that case
    they demoed it in that case
    not many impartial reviews yet
    but heres their ces promotion to show what it can do
    http://www.youtube.com/watch?v=bS5MVIA0OQ4
    I checked them out already. It looks promising. If I was this guy who's inquiring about CPU coolers then I'll grab the H80i. I got mine on sell for $80 and this costs $100. I believe amazon should have good price on this and if not try tigerdirect which is where I got mine.
  16. Hmm well how does the h80i perform? Ill need my cpu to be around 1.43.-14.6v for 5ghz Will it be able to keep it under 61c since thats the rated safe temp fro any FX cpu
    Also if i get the h100i and get rid of the top 240m. It shouldlnt hurt my gpu temps should it?.
    I got the 2 front 120ms sucking in air. and a back 120m
  17. i have an h80
    and other than replacing the stock fans have had no issues with it
    the swiftech unit will be dearer as its a far better pump--better cpu block --better fans--and copper radiator
    not aluminium
    plus the option of gpu cooling or more rads later if you want to
    for what it is compared to other pre-sealed units i think its a very good price
  18. The only Watercooling option thats easy for me to get my hands on (in Australia) without ebay and other stuff is the
    http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_45&products_id=21056
    XSPC RAYSTORM 750RS360
    Now the h100i and that are about $20 dollars difference the h100i being cheaper
    Hm.. i never considerd watercooling my gpu. I couldnt do it right away since its expensive and i got around $200 to spend on cooling (less the better) but yea
  19. XSPC RAYSTORM 750RS360 is a good kit
    but the pumps probably not up to adding gpu cooling to it
    and fitting a 360 rad in your case would be tricky
  20. http://www.gammods.com.au/store/index.php?main_page=product_info&cPath=1_122&products_id=6459&zenid=15f49929fc2ff339da4e2063bf99e63b that's a rx240 xspc I mean for the cpu it should do the job but idk about gpu. Hmm water cooling is hard :/
  21. there is a watercooling section here if you are interested they would be able to give more advice on
    custom loops--there are a lot of options
    thats why i am looking at the new swiftech unit
    you start off with something thats simple to install
    but has a pump thats capable of adding further stuff later and the reservoir is part of the rad
  22. I read first few post, the noctua preforms about the same as h100i, but if you think it's ugly you could buy some corsair fans and replace with the brown ones and you will see a performance boost as well.
    I think the fans on them are quality. Plus the air that comes out of the back is really directional compared to ordinary fans that shoot the air out in all directions. The CFM on the Noctua fans is pretty dam high. I can only think of one fan off the top of my head that is better than the Noctua ones and that is one Scythe manufacture.
    Corsair ones are pretty standard fans.
  24. This test shows most of the coolers i was considering
    http://www.hardwaresecrets.com/article/Thermaltake-Frio-OCK-CPU-Cooler-Review/1278/6
    The frio OCK (Nice looking cooler) Beat the nh-d14 By 3c But its much louder the nh-d14 is 49DBA and the Frio OCK is 60DBA
    I Think ill get the Thermaltake frio OCK. its cheaper than the nh-d14 performs better
    (from that test) But is much louder and spins faster. However i just cant stand the nh-d14
    And the OCK is cheaper here.
    http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_23_845&products_id=17015
    Anyone know anything about thermaltake coolers? Or the FRIO OCK?
CPUs Overclocking Cooling
