First build for gaming rig/55inch HDTV home theatre
Approximate Purchase Date: Within next 2 weeks
Budget Range: roughly around $1000
System Usage from Most to Least Important: Playing World of Warcraft at max settings as smooth as possible.
Also being used to connect to 55inch HDTV Samsung smart tv for a bluRay player and to watch HD downlaoded movies and storing movies ect.
Are you buying a monitor: Yes (with monitor can push budget up $200)
Do you need to buy OS: Yes
Preferred Website(s) for Parts:
https://www.pccasegear.com/
Overclocking: Maybe
SLI or Crossfire: eh?
Monitor Resolution: 1920x1080 when connected to tv, need to buy monitor.
Additional comments: Was looking at building a computer a few months ago for a budget of over $2000 but figured it was a little excessive for what id be using it for..
I do however might possibly need a good wireless network adapter due to the current house can only run on wireless not wired so the best connection possible would help.
can push budget to 1500 with OS and monitor..
1 answer Last reply
More about first build gaming 55inch hdtv home theatre
  1. Here you go:
    CPU: Intel Core i5-3450 3.1GHz Quad-Core Processor ($179.95 @ Mwave Australia)
    Motherboard: ASRock H77 Pro4-M Micro ATX LGA1155 Motherboard ($98.00 @ Mwave Australia)
    Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory
    Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($79.00 @ PCCaseGear)
    Storage: Samsung 830 Series 128GB 2.5" Solid State Disk ($109.00 @ Scorptec)
    Video Card: PowerColor Radeon HD 7850 2GB Video Card ($219.00 @ PCCaseGear)
    Case: Silverstone SST-GD08B (Black) HTPC Case ($159.00 @ PCCaseGear)
    Power Supply: Corsair Enthusiast 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($112.00 @ PCCaseGear)
    Optical Drive: Sony BWU-500S Blu-Ray/DVD/CD Writer ($139.00 @ Mwave Australia)
    Operating System: Microsoft Windows 7 Professional SP1 (64-bit) ($139.00 @ PCCaseGear)
    Total: $1233.95
    (Generated by PCPartPicker 2012-09-22 04:39 EST+1000)
    Add whatever monitor you want and you're good to go.
New Build Monitors Systems
