Laptop cooling fans not running!!
Hey!
This is my first post here!
So I've got a problem.
Yesterday I was surfing with my laptop, and i accidently knocked a glass of soda (fortunately sugar free) over, and it came under my laptop while on the table. Since then the PC keeps overheating and none of the fans are running. Is there something I can do about this?
Thanks in advance!
1 answer Last reply
More about laptop cooling fans running
  1. Contact your manufacturer and see if your laptop has warranty. You will have to send them the laptop for them to replace the fans...don't try to open it up and do it yourself as you will void warranty
Laptops Cooling Components
